[GRASS-dev] Download and access statistics for Addons
    Markus Neteler
    neteler at osgeo.org
    Fri Nov 20 14:01:45 PST 2015
Hi Vaclav,
On Nov 20, 2015 10:31 PM, "Vaclav Petras" <wenzeslaus at gmail.com> wrote:
> Hi Markus,
> On Sat, Nov 14, 2015 at 8:17 AM, Markus Neteler <neteler at osgeo.org> wrote:
>> Yes. We could install piwik for that.
>> No big deal (I use it for a while elsewhere).
> will you have some time to do it?
It is no big deal. I already spoke to SAC about it but didn't get a real
answer.
> I wonder if there is something I can do, like adding something to the
documentation, but I really have no experience with it.
I do, so we only need to know where to install it.
> I guess it requires some privacy line as well.
Yep. But I studied the options already, also feasible.
>  These things should be probably patched to the doc later on by a script
only on the build server.
It is done in piwik itself.
So, I'll ask again if I can install it on osgeo6.
Then we just need to add something to the template(s).
Ciao
Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151120/d7f92b6f/attachment.html>
