[GRASS-dev] GRASS 7.1 compiles but won't run
Vaclav Petras wenzeslaus at gmail.com
Mon Nov 23 13:25:12 PST 2015
On Mon, Nov 23, 2015 at 4:22 PM, Martin Landa <landa.martin at gmail.com>
wrote:
> 2015-11-23 22:13 GMT+01:00 Michael Barton <Michael.Barton at asu.edu>:
> "/Users/cmbarton/grass_source/grass_trunk/macosx/dist/GRASS-7.1.app/Contents/MacOS/gui/wxpython/lmgr/frame.py",
> > line 73, in <module>
> >     from datacatalog.catalog   import DataCatalog
> > ImportError: No module named catalog
> please check ML, there are several mail about that. Completely remove
> current installation and re-compile from scratch. Ma
When you are building after long time, you should always build from scratch
(make distclean). Some changes, like moving files, require cleaning the
distribution directory and there is no way around it, r66128 was one of
them.
https://trac.osgeo.org/grass/changeset/66128
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151123/bb6fb8f1/attachment-0001.html>
