[GRASS-dev] [GRASS GIS] #2770: r.mapcalc reports syntax error for valid script but no error for separate expressions
GRASS GIS trac at osgeo.org
Tue Nov 24 22:28:58 PST 2015
expressions
  Reporter:  marisn       |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.0.3
 Component:  Raster       |    Version:  svn-trunk
Resolution:               |   Keywords:  r.mapcalc
       CPU:  Unspecified  |   Platform:  Unspecified
Changes (by marisn):
 * milestone:   => 7.0.3
Comment:
 If I understood correctly, r.mapcalc works like this:
 for output_row in computational_region:
     for output_cell in output_row:
         first expression
         second expression
         third expression
 thus "first" becomes a map only at the end of r.mapcalc run.
 Leaving open as an update to documentation is needed (I'll try to write it
 if above logic is correct).
Ticket URL: <https://trac.osgeo.org/grass/ticket/2770#comment:2>
