[GRASS-dev] proposal for g.search module
Jachym Cepicky jachym.cepicky at gmail.com
Fri Nov 27 15:06:07 PST 2015
ahoj Vašku,
not sure about the maps. wouldn't be better to extend g.list?
about the name: g.module.search?
need to work on the output a bit more...
would -g flag be useful as well?
glad you like it
jachym
On Fri, Nov 27, 2015, 17:13 Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Fri, Nov 27, 2015 at 10:51 AM, Jachym Cepicky <jachym.cepicky at gmail.com
> > wrote:
>> Hi all,
>> I've tried to implement command line alternative to module search based
>> on keywords, which is available in the gui - it's called g.search
>> Any chance, you might find this useful ? Any comment to the source code
>> and outputs?
>> https://github.com/jachym/g.search
> I think it is awesome:
> $ g.extension extension=g.search url=https://github.com/jachym/g.search
> $ g.search MLC
> i.gensig
>     Description: Generates statistics for i.maxlik from raster map.
>     Keywords: imagery,classification,supervised classification,Maximum
> Likelihood Classification,MLC,signatures
> i.maxlik
>     Description: Classifies the cell spectral reflectances in imagery
> data. Classification is based on the spectral signature information
> generated by either i.cluster, g.gui.iclass, or i.gensig.
>     Keywords: imagery,classification,Maximum Likelihood Classification,MLC
> The code is minimalistic, so the duplication with GUI code is minimal or
> none.
> I suggest to put it to trunk, but to consider the name first. g.search
> sounds good but does it search modules or maps or both? Are the maps a
> possible extension of the current functionality?
> Vaclav
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151127/bc95355f/attachment.html>
