[GRASS-dev] proposal for g.search module
Markus Neteler neteler at osgeo.org
Sat Nov 28 15:04:21 PST 2015
Hi Jachym,
On Fri, Nov 27, 2015 at 4:51 PM, Jachym Cepicky
<jachym.cepicky at gmail.com> wrote:
> Hi all,
> I've tried to implement command line alternative to module search based on
> keywords, which is available in the gui - it's called g.search
GRASS 7.1.svn (nc_spm_08_grass7):~ > g.extension g.search
url=https://github.com/jachym/g.search
Fetching <g.search> from
<https://github.com/jachym/g.search/archive/master.zip> (be patient)...
Compiling...
Installing...
Installation of <g.search> successfully finished
GRASS 7.1.svn (nc_spm_08_grass7):~ > g.search watershed
r.watershed
    Description: Calculates hydrological parameters and RUSLE factors.
    Keywords: raster,hydrology,watershed
r.water.outlet
    Description: Creates watershed basins from a drainage direction map.
r.basins.fill
    Description: Generates watershed subbasins raster map.
So cool!!! Thank you,
Markus
