[GRASS-dev] installing v.mapcalc fails
Glynn Clements
glynn at gclements.plus.com
Thu Oct 1 03:38:46 PDT 2015
Moritz Lennert wrote:
> > yylex.c:9:27: fatal error: v.mapcalc.tab.h: No such file or directory
> > #include "v.mapcalc.tab.h"
> > compilation terminated.
> > make: *** [OBJ.x86_64-unknown-linux-gnu/yylex.o] Error 1
> > ERROR: Compilation failed, sorry. Please check above error messages.
> Glynn, can you help us on this ? We need to find the correct Makefile
> for the v.mapcalc addon [1]
That header is generated by yacc (or byacc, bison, etc) via a pattern
rule in include/Make/Compile.make:
%.output %.tab.h %.tab.c: %.y
$(YACC) -b$* $(YFLAGS) $<
The problem with v.mapcalc is that it tries to compile yylex.c before
v.mapcalc.tab.h has been generated, which fails. It requires:
-yylex.c: v.mapcalc.tab.h
+$(OBJDIR)/yylex.o: v.mapcalc.tab.h
The header is a dependency of the object file; the source file doesn't
have dependencies (it's a source file, not generated).
Committed in r66392.
