[GRASS-dev] installing v.kriging addon fails
Paulo van Breugel p.vanbreugel at gmail.com
Thu Oct 1 06:26:20 PDT 2015
On 01-10-15 14:36, Markus Neteler wrote:
> On Thu, Oct 1, 2015 at 12:51 PM, Paulo van Breugel
> <p.vanbreugel at gmail.com> wrote:
>> I already had GRASS compiled with both blas and lapack, so that doesn't seem
>> to help in my case (just tried again, still no luck).
> You may try to checkout the Addon code from SVN and compile there:
> cd grass-addons/grass7/vector/v.kriging/
> make MODULE_TOPDIR=/path/to/grass7
Tried it, but no luck:
paulo at paulo-HPZ600:~/Software/spatial/grass-addons/vector/v.kriging$ make MODULE_TOPDIR=/usr/local/grass7/grass-7.1.svn
gcc  -g -O2   -I/usr/local/grass7/grass-7.1.svn/include -I/usr/local/grass7/grass-7.1.svn/include   -I/usr/local/gdal/include -I/usr/include -DPACKAGE=\""grassmods"\"  -I/usr/include/postgresql -I/usr/local/gdal/include -I/usr/local/grass7/grass-7.1.svn/include -I/usr/local/grass7/grass-7.1.svn/include -DRELDIR=\"/home/paulo/Software/spatial/grass-addons/vector/v.kriging\" -o OBJ.x86_64-unknown-linux-gnu/geostat.o -c geostat.c
In file included from geostat.c:1:0:
local_proto.h:72:3: error: unknown type name ‘mat_struct’
    mat_struct *trend;
local_proto.h:113:3: error: unknown type name ‘mat_struct’
    mat_struct *gamma;    // experimental variogram matrix
local_proto.h:124:3: error: unknown type name ‘mat_struct’
    mat_struct *A;           // plan matrix
local_proto.h:125:3: error: unknown type name ‘mat_struct’
    mat_struct *T;           // coefficients of theoretical variogram
local_proto.h:126:3: error: unknown type name ‘mat_struct’
    mat_struct *GM;          // GM = theor_var(dist: input, output points)
local_proto.h:218:1: error: unknown type name ‘mat_struct’
  mat_struct *LSM(mat_struct *, mat_struct *);
local_proto.h:218:17: error: unknown type name ‘mat_struct’
local_proto.h:218:31: error: unknown type name ‘mat_struct’
local_proto.h:219:1: error: unknown type name ‘mat_struct’
  mat_struct *nonlin_LMS(int , double *, double *);
local_proto.h:226:24: error: unknown type name ‘mat_struct’
  double bivar_sill(int, mat_struct *);
local_proto.h:245:68: error: unknown type name ‘mat_struct’
  void write2file_variogram_E(struct int_par *, struct parameters *, mat_struct *);
local_proto.h:250:1: error: unknown type name ‘mat_struct’
  mat_struct *set_up_G(struct points *, struct parameters *, struct write *);
local_proto.h:251:1: error: unknown type name ‘mat_struct’
  mat_struct *set_up_g0(struct int_par *, struct points *, struct ilist *, double *, struct parameters *);
local_proto.h:252:1: error: unknown type name ‘mat_struct’
  mat_struct *submatrix(struct ilist *, mat_struct *, struct write *);
local_proto.h:252:39: error: unknown type name ‘mat_struct’
local_proto.h:253:49: error: unknown type name ‘mat_struct’
  double result(struct points *, struct ilist *,  mat_struct *);
geostat.c: In function ‘E_variogram’:
geostat.c:101:5: error: unknown type name ‘mat_struct’
      mat_struct *gamma_M;        // gamma matrix (hz, vert or bivar)
geostat.c:102:5: error: unknown type name ‘mat_struct’
      mat_struct *c_M;            // matrix of # of dissimilarities
geostat.c:145:9: warning: assignment makes pointer from integer without a cast [enabled by default]
      c_M = G_matrix_init(nrows, ncols, nrows);   // temporal matrix of counts
geostat.c:146:13: warning: assignment makes pointer from integer without a cast [enabled by default]
      gamma_M = G_matrix_init(nrows, ncols, nrows);       // temporal matrix (vector) of gammas
geostat.c:158:13: error: request for member ‘vals’ in something not a structure or union
      c = &c_M->vals[0];
geostat.c:159:21: error: request for member ‘vals’ in something not a structure or union
      gamma = &gamma_M->vals[0];
geostat.c:308:21: warning: assignment makes pointer from integer without a cast [enabled by default]
      var_pars->gamma = G_matrix_copy(gamma_M);
geostat.c: In function ‘ordinary_kriging’:
geostat.c:516:5: error: unknown type name ‘mat_struct’
      mat_struct *GM;
geostat.c:517:5: error: unknown type name ‘mat_struct’
      mat_struct *GM_sub;         // submatrix of selected points
geostat.c:518:5: error: unknown type name ‘mat_struct’
      mat_struct *GM_Inv;         // inverted GM (GM_sub) matrix
geostat.c:519:5: error: unknown type name ‘mat_struct’
      mat_struct *g0;             // diffences between known and unknown values = theor_var(dist)
geostat.c:520:5: error: unknown type name ‘mat_struct’
      mat_struct *w0;             // weights of values located on the input points
geostat.c:545:17: warning: assignment makes pointer from integer without a cast [enabled by default]
      var_par->GM = G_matrix_copy(GM);    // copy matrix because of cross validation
geostat.c:589:28: warning: assignment makes pointer from integer without a cast [enabled by default]
                      GM_sub = submatrix(list, GM, report);       // make submatrix for selected points
geostat.c:590:28: warning: assignment makes pointer from integer without a cast [enabled by default]
                      GM_Inv = G_matrix_inverse(GM_sub);  // invert submatrix
geostat.c:594:24: warning: assignment makes pointer from integer without a cast [enabled by default]
                      w0 = G_matrix_product(GM_Inv, g0);  // Vector of weights, condition SUM(w) = 1 in last row
make: *** [OBJ.x86_64-unknown-linux-gnu/geostat.o] Error 1
> Markus
