[GRASS-dev] installing v.kriging addon fails
Paulo van Breugel
p.vanbreugel at gmail.com
Thu Oct 1 07:40:12 PDT 2015
On 01-10-15 15:35, Vaclav Petras wrote:
> On Thu, Oct 1, 2015 at 9:29 AM, Markus Neteler <neteler at osgeo.org
> <mailto:neteler at osgeo.org>> wrote:
> > > In file included from geostat.c:1:0:
> > > local_proto.h:72:3: error: unknown type name ‘mat_struct’
> > > mat_struct *trend;
> > ok - next check:
> > cd /where/your/grass/is/lib
> > ldd libgrass_gmath.so | grep 'blas\|lapack'
> > liblapack.so.3 => /lib64/liblapack.so.3 (0x00007f640ac4f000)
> > libblas.so.3 => /lib64/libblas.so.3 (0x00007f640a9f5000)
> > Is your GMATH lib properly linked to BLAS/LAPACK? Here it is and it
> compiles.
> "unknown type name ‘xy’" really looks like that GRASS is not compiled
> with BLAS and LAPACK. I suggest to double check the configuration. You
> can also try to compile i.spec.unmix which always had an explicit
> check for BLAS and LAPACK configuration. (v.kriging compiles for me.)
Did a completely clean install of GRASS, which did the trick.. v.kriging
compiles now without problems. Thanks.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151001/1c8bcc56/attachment.html>
