[GRASS-dev] [GRASS-SVN] r66413 - grass-addons/grass7/vector/v.kriging
Martin Landa landa.martin at gmail.com
Mon Oct 5 00:41:31 PDT 2015
2015-10-05 3:04 GMT+02:00 Vaclav Petras <wenzeslaus at gmail.com>:
> this shouldn't be necessary and same for r66404, gmath.h contains already
> grass/la.h. Any possible compilation issue is an issue with configuration
> (local or in GRASS) or with the gmath.h file. What was the reason for the
> change?
compilation was simply failing on build server (Debian stable):
> In file included from main.c:47:0:
> global.h:28:29: error: unknown type name ‘vec_struct’
> global.h:28:43: error: unknown type name ‘vec_struct’
> global.h:31:8: error: unknown type name ‘mat_struct’
Ma
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
