[GRASS-dev] wx.metadata ready for testing
Matej Krejci
matejkrejci at gmail.com
Mon Oct 5 01:39:54 PDT 2015
Hi Martin and others,
2015-10-04 14:33 GMT+02:00 Martin Landa <landa.martin na gmail.com>:
> Hi all,
> recently I fixed some compilation and installation issues of
> wx.metadata addons [1] (GSoC 2014 & 2015 project of Matej Krejci). Now
> it's possible to install it via `g.extension`.
> Martine, thanks for work on it.
Testing welcome. Martin
I just checked .grass7/addons/etc/wx.metadata and installation deployed
only /mdlib dir but no /configure and /profiles dirs. It is the same issue
like r.green[1]. Correctly placed directories should looks like:
matt na matt-pc:~/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/wx.metadata$
tree
├── config
│ ├── connections_resources.xml
│ ├── default-sample.cfg
│ ├── init_md.txt
│ ├── keywordConcepts.txt
│ ├── keywordGroups.txt
│ ├── keywordThemes.txt
│ ├── record_metadata_dc.html
│ ├── service_metadata.html
│ ├── xml_highlight.html
│ └── xml_render.html
├── mdlib
│ ├── cswlib.py
│ ├── cswlib.pyc
│ ├── cswutil.py
│ ├── cswutil.pyc
│ ├── mdeditorfactory.py
│ ├── mdeditorfactory.pyc
│ ├── mdgrass.py
│ ├── mdgrass.pyc
│ ├── mdjinjaparser.py
│ ├── mdjinjaparser.pyc
│ ├── mdpdffactory.py
│ ├── mdpdffactory.pyc
│ ├── mdpdftheme.py
│ ├── mdpdftheme.pyc
│ ├── mdutil.py
│ └── mdutil.pyc
└── profiles
├── basicProfile.xml
├── inspireProfile.xml
└── temporalProfile.xml
This example is created by local installation which works well.
matt na matt-pc:~/addons/grass7/gui/wxpython/wx.metadata$ make
MODULE_TOPDIR=$HOME/grass_trunk & make MODULE_TOPDIR=$HOME/grass_trunk
install
I am not sure if this issue is about Makefile or not.
Thanks for any idea.
matej
[1] https://lists.osgeo.org/pipermail/grass-dev/2015-August/076034.html
------------- dal�� ��st ---------------
HTML p��loha byla odstran�na...
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151005/ddd389f6/attachment-0001.html>
