[GRASS-dev] I've tripled GRASS's I/O speed
Seth Price seth at planet.com
Mon Oct 5 15:41:13 PDT 2015
The tests are without my changes on 64 bit Mac v10.10.5, Mac Pro with 64 GB
of RAM.
./configure  --with-freetype
--with-freetype-includes=/usr/local/include/freetype2 --with-opengl=aqua
--with-libs=/usr/local/lib --enable-64bit --with-sqlite --with-postgres
--with-postgres-includes=/usr/local/pgsql/include
On Mon, Oct 5, 2015 at 3:34 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Mon, Oct 5, 2015 at 6:23 PM, Seth Price <seth at planet.com> wrote:
>> Ah, I see now. I have failed tests at 24% & 21% on a recent snapshot now:
>> GRASS 7.1.svn
>> (ncarolina_smp_base0.3.2):/usr/local/grass/grass-7.1.svn_src_snapshot_2015_09_19
>> > python -m grass.gunittest.main --location ncarolina_smp_base0.3.2
>> --location-type nc
>> test_assertions_vect from ./lib/python/gunittest failed (1 test failed)
>> test_doctests from ./lib/python/pygrass failed (3 tests failed)
>> test_v_net from ./vector/v.net failed (4 tests failed)
>> test_vwhat_ncspm from ./vector/v.what failed (4 tests failed)
>> Executed 127 test files in 0:24:05.986559.
>> From them 96 files (76%) were successful and 31 files (24%) failed.
>> GRASS 7.1.svn
>> or
>> GRASS 7.1.svn
>> (nc_basic_spm_grass7):/usr/local/grass/grass-7.1.svn_src_snapshot_2015_09_19
>> > python -m grass.gunittest.main --location nc_basic_spm_grass7
>> --location-type nc
>> test_raster3d_algebra from ./temporal/t.rast3d.algebra failed (6 tests
>> failed)
>> test_vector_algebra from ./temporal/t.vect.algebra failed (14 tests
>> failed)
>> Executed 127 test files in 0:24:47.877746.
>> From them 100 files (79%) were successful and 27 files (21%) failed.
>> GRASS 7.1.svn
>> Is this expected?
> This looks quite OK actually. Probably most of the failing tests are
> temporal algebra which depends on Python PLY:
> https://grass.osgeo.org/grass70/source/snapshot/REQUIREMENTS.html
> This should be visible in the HTML reports (the aforementioned
> testreport/index.html) which give the actual reasons why the test failed.
> This is the result you will get today in best case (on 64bit):
> http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2015-10-05-07-00/report_for_nc_basic_spm_grass7_nc/testfiles.html
> Was this result with or without your changes?
>> On Mon, Oct 5, 2015 at 2:13 PM, Vaclav Petras <wenzeslaus at gmail.com>
>> wrote:
>>> On Mon, Oct 5, 2015 at 5:07 PM, Seth Price <seth at planet.com> wrote:
>>> > --location /usr/local/grass/nc_basic_spm_grass7/
>>> python -m grass.gunittest.main --location locname --location-type nc
>>> where locname is a name of location in current GRASS GIS data(base)
>>> directory (GISDBASE) and nc is a location specified by individual test
>>> files (the later is not yet fully implemented, so just put there nc every
>>> time).
>>> https://grass.osgeo.org/grass71/manuals/libpython/gunittest_running_tests.html#running-tests-and-creating-report
>>> or:
>>> grass71 --exec python -m grass.gunittest.main --help
>>>   --location LOCATION   Name of location where to perform test
>>> I hope this helps.
>>> Have you found the HTMl output?
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151005/c635f353/attachment-0001.html>
