[GRASS-dev] v.rast.stats: NULL values for very small areas
Moritz Lennert mlennert at club.worldonline.be
Tue Oct 6 09:26:28 PDT 2015
On 06/10/15 17:51, Martin Landa wrote:
> Hi,
> 2015-10-06 17:29 GMT+02:00 Moritz Lennert <mlennert at club.worldonline.be>:
>> One can argue that setting them NULL is actually a valid choice as it might
>> not be legitimate to give them values of pixel so much larger. But maybe
>> this should be decided by a flag ?
> right, a flag could be an option.
>> Get area and if area < pixel size then
>> - number = 1
> There can be more areas with same category.
Yes, but the 'number' statistic gives you the number of pixels in the
area. This number is important to interpret the other statistics (a mean
and stddev based on 2 pixels do not necessarily have the same
statistical value as the same statistics based on several hundred
pixels). Putting number = 1 is a bit of a 'lie', here as there is less
than a pixel in the area, but the only way to get any numbers into the
statistics is to use the value of a pixel, so number=1 means: we used
one single pixel to determine these statistics.
>> - range = 0
>> - stddev,variance,coeff_var = 0 (or NULL)
>> - all other values = pixel value which you can get by replacing the areas by
>> their centroids, you could use v.what.rast to get the pixel value.
>> But I wonder if this is not a bit of overkill...
> Why? I have request from the users, they are not happy about NULL
> values.
But, as already said, one could argue that NULL is the  scientifically
most correct answer in this case...
v.rast.stats is not about getting pixel values, but about getting
statistics of collections of pixel values. When you do not even have one
single pixel entirely containted in the area, then it makes sense to say
that you cannot calculate any statistics and set the value to NULL.
If you just want pixel values, you can always use v.what.rast based on
the area centroids.
> I just wonder how to implement within Python script.
Get areas of all polygons (or lenghts of lines) with v.to.db and then
divide the features into those with areas above pixel size and those
with areas below. Treat each set differently (i.e. the former as before,
the latter by using v.what.rast - with the -p flag - to get the pixel
value). As the updating of the table is done feature by feature anyhow,
all you lose in terms of performance is the additional step of
calculating areas/lengths of features.
> Probably
> rewriting to C would make sense(?)
It might make it more efficient, but I think the python version would
work well and the change in python version should not be too complicated.
Moritz
