[GRASS-dev] wx.metadata ready for testing
Blumentrath, Stefan Stefan.Blumentrath at nina.no
Wed Oct 7 14:15:34 PDT 2015
Hi Martin,
Thanks for your patience.
Here is my shell output:
GRASS 7.1.svn (ETRS_32N):~/data_maintenance > env | grep GIS
GISRC=/tmp/grass7-stefan-19203/gisrc
GISBASE=/usr/local/grass-7.1.svn
GIS_LOCK=19203
GRASS 7.1.svn (ETRS_32N):~/data_maintenance > env | grep GRASS
GRASS_PYTHON=python
GRASS_GNUPLOT=gnuplot -persist
GRASS_PAGER=more
GRASS_ADDON_PATH=/home/stefan/grass-addons/
GRASS_PROJSHARE=/usr/local/share/proj
GRASS_VERSION=7.1.svn
GRASS_SKIP_MAPSET_OWNER_CHECK=1
GRASS_HTML_BROWSER=xdg-open
GRASS_ADDON_BASE=/home/stefan/.grass7/addons
GRASS 7.1.svn (ETRS_32N):~/data_maintenance > export GRASS_ADDON_PATH=/home/stefan/.grass7/addons/
GRASS_PYTHON=python
GRASS_PAGER=more
GRASS 7.1.svn (ETRS_32N):~/data_maintenance > g.extension wx.metadata
Fetching <wx.metadata> from GRASS GIS Addons repository (be patient)...
Compiling...
  File "/tmp/grass7-stefan-19203/tmpQpQIQ7/wx.metadata/scripts/db.csw.admin", line 127, in <module>
    from cswutil import *
ImportError: No module named cswutil
make[1]: *** [db.csw.admin.tmp.html] Error 1
/bin/sh: 1: cannot create /usr/local/grass-7.1.svn/error.log: Permission denied
make: *** [db.csw.admin] Error 2
ERROR: Compilation failed, sorry. Please check above error messages.
GRASS 7.1.svn (ETRS_32N):~/data_maintenance > g.version -g
version=7.1.svn
date=2015
revision=66426M
build_date=2015-10-07
build_platform=x86_64-unknown-linux-gnu
build_off_t_size=8
Cheers
Stefan
-----Original Message-----
From: grass-dev-bounces at lists.osgeo.org [mailto:grass-dev-bounces at lists.osgeo.org] On Behalf Of Martin Landa
Sent: 7. oktober 2015 22:30
To: Paulo van Breugel <p.vanbreugel at gmail.com>
Cc: GRASS developers list <grass-dev at lists.osgeo.org>
Subject: Re: [GRASS-dev] wx.metadata ready for testing
2015-10-07 12:30 GMT+02:00 Paulo van Breugel <p.vanbreugel at gmail.com>:
I tried fresh installation (trunk) in installed to /usr/local. I cannot reproduce any of reported errors. Please send me related environmental variables:
env | grep GIS
env | grep GRASS
Ma
> ware/spatial/grass-addons/gui/wxpython/wx.metadata/g.gui.metadata
>> >>> /usr/local/grass7/grass-7.1.svn/error.log
>> > make[1]: Entering directory
>> > `/home/paulo/Software/spatial/grass-addons/gui/wxpython/wx.metadata/g.gui.metadata'
>> > if [ "/usr/local/grass7/grass-7.1.svn/scripts/g.gui.metadata" != ""
>> > ] ; then
>> > GISRC=/usr/local/grass7/grass-7.1.svn/demolocation/.grassrc71
>> > GISBASE=/usr/local/grass7/grass-7.1.svn
>> > PATH="/usr/local/grass7/grass-7.1.svn/bin:/usr/local/grass7/grass-7.1.svn/bin:/usr/local/grass7/grass-7.1.svn/scripts:$PATH"
>> > PYTHONPATH="/usr/local/grass7/grass-7.1.svn/etc/python:/usr/local/grass7/grass-7.1.svn/gui/wxpython:$PYTHONPATH"
>> > LD_LIBRARY_PATH="/usr/local/grass7/grass-7.1.svn/bin:/usr/local/grass7/grass-7.1.svn/scripts:/usr/local/grass7/grass-7.1.svn/lib:/usr/local/grass7/grass-7.1.svn/lib::/lib:/usr/local/lib:/usr/local/gdal/lib"
>> > LC_ALL=C /usr/local/grass7/grass-7.1.svn/scripts/g.gui.metadata
>> > --html-description < /dev/null | grep -v '</body>\|</html>' >
>> > g.gui.metadata.tmp.html ; fi
>> >   File "/usr/local/grass7/grass-7.1.svn/scripts/g.gui.metadata",
>> > line 35, in <module>
>> >     import mdgrass
>> > ImportError: No module named mdgrass
>> > make[1]: *** [g.gui.metadata.tmp.html] Error 1
>> > rm g.gui.metadata.tmp.html
>> > make[1]: Leaving directory
>> Martin Landa
>> http://geo.fsv.cvut.cz/gwiki/Landa
>> http://gismentors.cz/mentors/landa
Martin Landa
grass-dev mailing list
http://lists.osgeo.org/mailman/listinfo/grass-dev
