[GRASS-dev] [GRASS GIS] #2750: LZ4 when writing raster rows; better than double I/O bound r.mapcalc speed
trac at osgeo.org
Sat Oct 10 09:47:42 PDT 2015
Reporter: sprice | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.1.0
Component: Raster | Version: svn-trunk
Resolution: | Keywords: ZLIB LZ4 ZSTD
CPU: OSX/Intel | Platform: MacOSX
Comment (by wenzeslaus):
Replying to [comment:11 sprice]:
> Completely random data is not a good test because (in theory) it won't
compress. However, it looks like it demonstrated the expected results.
Yes, probably G7:r.surf.fractal or G7:r.random.surface are better, but
G7:r.mapcalc with `rand()` is kind of worst-case scenario and the
compression still worked well!
> If you do a diff with n_les_assemble.c...
I've created a separate ticket #2754 for this. Let's discuss it there.
I've executed the tests with `GRASS_COMPRESS_NULLS=1` in combination with
default compression and `GRASS_INT_LZ4=1` and they seems to be OK
(although there is some issue with ''r.slope.aspect'' test but that's
unrelated). But still, the test coverage is limited, user testing is
needed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2750#comment:12>
