[GRASS-dev] [GRASS-SVN] r66466 - in grass/branches/releasebranch_7_0/scripts: . r.import v.import
Anna Petrášová kratochanna at gmail.com
Sat Oct 10 12:05:44 PDT 2015
On Sat, Oct 10, 2015 at 3:00 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Sat, Oct 10, 2015 at 8:00 PM,  <svn_grass at osgeo.org> wrote:
> > Author: annakrat
> > Date: 2015-10-10 11:00:10 -0700 (Sat, 10 Oct 2015)
> > New Revision: 66466
> > Added:
> >    grass/branches/releasebranch_7_0/scripts/r.import/
> >    grass/branches/releasebranch_7_0/scripts/v.import/
> > Removed:
> >    grass/branches/releasebranch_7_0/scripts/r.import/testsuite/
> > Modified:
> >    grass/branches/releasebranch_7_0/scripts/Makefile
> >    grass/branches/releasebranch_7_0/scripts/v.import/v.import.py
> > Log:
> > add v.import/r.import from trunk
> There are a few differences between
> grass70/scripts/v.import/v.import.py
> grass71/scripts/v.import/v.import.py
> ... all on purpose? Just to be sure.
Should be. v.in.ogr for some reason doesn't have -j in 71 and there are
changes in the interface because there is special widget in 71 which should
still be tested more.
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151010/5d1e6787/attachment.html>
