[GRASS-dev] [GRASS GIS] #2755: Commandline switch "/S" is not working anymore
GRASS GIS trac at osgeo.org
Mon Oct 12 00:07:53 PDT 2015
 Reporter:  derseppel     |      Owner:  grass-dev@…
     Type:  defect        |     Status:  new
 Priority:  normal        |  Milestone:
Component:  Installation  |    Version:  7.0.1
 Keywords:                |        CPU:  Unspecified
 Platform:  MSWindows 7   |
 When using the "WinGRASS-7.0.1-1-Setup.exe" with the Commandline parameter
 "/S" to perform a silent installation a window appears.
 This window is asking me if I wish to install the MS Visual C++ Packages
 (see attachment).
 With the old "WinGRASS-7.0.0-1-Setup.exe" everything works fine.
 IDK which default action should be applied here. For me it would be OK
 when the installer simply does not install any MS Visual C++ Packages.
 Best way would be (maybe a lot of work to do here) to check if the VC++
 Packages are installed and add them only if they are not.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2755>
