[GRASS-dev] Using a dynamic text in module header for parser
Blumentrath, Stefan Stefan.Blumentrath at nina.no
Mon Oct 12 03:55:58 PDT 2015
Hi again,
Now I found out that the parser section in the inner python script was not formated properly.
However, when I now call the inner script with '--ui' I get an error:
Unable to fetch interface description for command 'tmpjksdfjiol'
Details:
Try to set up GRASS_ADDON_PATH or GRASS_ADDON_BASE variable.
It was neither possible to run the script using grass.run_command() (on Windows).
Cheers
Stefan
From: grass-dev [mailto:grass-dev-bounces at lists.osgeo.org] On Behalf Of Blumentrath, Stefan
Sent: 12. oktober 2015 11:36
To: GRASS developers list (grass-dev at lists.osgeo.org) <grass-dev at lists.osgeo.org>
Subject: [GRASS-dev] Using a dynamic text in module header for parser
I would like to fill:
#% options:
and
#% answer
in a parser option for a python script dynamically.  In particular I want to have tickboxes for available mapsets in the module GUI...
Meaning something like this  (but less complex / not interactive):
http://permalink.gmane.org/gmane.comp.gis.grass.gui/667
My amateur programming skills do unfortunately not allow me to really understand how to accomplish what Glynn describes in the post above...
I tried to generate and run a temporary python script from within my script like this:
def main():
    answer = grass.mapsets(search_path = True)
    available_mapsets = str(grass.mapsets())
    with tempfile.NamedTemporaryFile(delete = False) as s:
        s.write('''    #!/usr/bin/env python
# -*- coding: utf-8 -*-
# Here comes the full module with header for the parser
#% options: ''' + str(','.join(available_mapsets))
    startcmd = 'python ' + s.name
    os.system(startcmd)
    os.remove(s.name)
But that way the GUI never starts, when I call the outer script from GRASS and it seems that option never get parsed...
Any hints how to proceed?
Thanks for helping in advance.
Stefan
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151012/0ed4a5f2/attachment.html>
