[GRASS-dev] [GRASS GIS] #2757: r.import: ERROR: Input raster map is outside current region
GRASS GIS trac at osgeo.org
Mon Oct 12 14:19:16 PDT 2015
 Reporter:  neteler      |      Owner:  grass-dev@…
     Type:  defect       |     Status:  new
 Priority:  normal       |  Milestone:  7.0.2
Component:  Python       |    Version:  svn-trunk
 Keywords:  r.import     |        CPU:  Unspecified
 Platform:  Unspecified  |
 Both in trunk and relbranch70 (r66401 for a needed backport) I face a
 problem with r.import:
 # get Bioclim data
 wget
 http://biogeo.ucdavis.edu/data/climate/worldclim/1_4/grid/cur/bio_2-5m_bil.zip
 # unpack bioclim1
 unzip bio_2-5m_bil.zip bio1.bil bio1.hdr
 # check
 gdalinfo bio1.bil
 Driver: EHdr/ESRI .hdr Labelled
 Files: bio1.bil
        bio1.hdr
 Size is 8640, 3600
 Coordinate System is:
 GEOGCS["WGS 84",
     DATUM["WGS_1984",
         SPHEROID["WGS 84",6378137,298.257223563,
             AUTHORITY["EPSG","7030"]],
         TOWGS84[0,0,0,0,0,0,0],
         AUTHORITY["EPSG","6326"]],
     PRIMEM["Greenwich",0,
         AUTHORITY["EPSG","8901"]],
     UNIT["degree",0.0174532925199433,
         AUTHORITY["EPSG","9108"]],
     AUTHORITY["EPSG","4326"]]
 Origin = (-180.000000000003354,90.000000000000028)
 Pixel Size = (0.041666666666667,-0.041666666666667)
 Corner Coordinates:
 Upper Left  (-180.0000000,  90.0000000) (180d 0' 0.00"W, 90d 0' 0.00"N)
 Lower Left  (-180.0000000, -60.0000000) (180d 0' 0.00"W, 60d 0' 0.00"S)
 Upper Right ( 180.0000000,  90.0000000) (180d 0' 0.00"E, 90d 0' 0.00"N)
 Lower Right ( 180.0000000, -60.0000000) (180d 0' 0.00"E, 60d 0' 0.00"S)
 Center      (  -0.0000000,  15.0000000) (  0d 0' 0.00"W, 15d 0' 0.00"N)
 Band 1 Block=8640x1 Type=Int16, ColorInterp=Undefined
   Min=-278.000 Max=319.000
   NoData Value=-9999
 # The goal is to reproject and import just
 # the NC portion of the Bioclim1 map:
 GRASS 7.1.svn (nc_spm_08_grass7): > g.region -dp
 projection: 99 (Lambert Conformal Conic)
 zone:       0
 datum:      nad83
 ellipsoid:  a=6378137 es=0.006694380022900787
 north:      320000
 south:      10000
 west:       120000
 east:       935000
 nsres:      500
 ewres:      500
 rows:       620
 cols:       1630
 cells:      1010600
 GRASS 7.1.svn (nc_spm_08_grass7): > r.import input=bio1.bil
 output=bioclim1 resample=bilinear extent=region resolution=region
 Proceeding with import of 1 raster bands...
 WARNING: Fixing subtle input data rounding error of north boundary
          (2.84217e-14>2.77778e-07)
 Importing raster map <bioclim1>...
  100%
 Estimated target resolution for input band <bioclim1>: 4021.79
 Reprojecting <bioclim1>...
 ERROR: Unable to to reproject raster <bioclim1>
 # while I don't really know what -n means:
 output=bioclim1 resample=bilinear extent=region resolution=region -n
  100%
 GRASS 7.1.svn (nc_spm_08_grass7): > r.info -r bioclim1
 min=-nan
 max=-nan
 The import of the requested map subset is not working.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2757>
