[GRASS-dev] Error reading raster data for row xxx (only when using r.series and t.rast.series)
Moritz Lennert
mlennert at club.worldonline.be
Tue Oct 13 01:04:50 PDT 2015
On 12/10/15 23:35, Dylan Beaudette wrote:
> Hi,
> Over the last couple of years I have noticed a very strange raster
> corruption (?) issues when using r.series, and now more recently,
> t.rast.series. Typically, I'll generate a large number of maps with
> r.sun or t.rast.mapcalc and then aggregate the series with r.series or
> t.rast.series. About 50% of the time the command runs as expected, the
> other half of the time r.series or t.rast.series gives me an error
> like this:
> Error reading raster data for row xxx (testmap)
> After this error, I can no longer perform any kind of operation on map
> "testmap" without the dreaded Error reading raster data for row xxx...
> The situation was worse when using a MASK map, possibly related to a
> similar (fixed?) issue discussed in this thread:
> http://lists.osgeo.org/pipermail/grass-dev/2015-July/075627.html
> Within that thread, Glynn mentioned that this type of error was
> probably related to pthreads and concurrent processes. The temporary
> fix entailed:
> export WORKERS=0
> I have tried this on my machine but the results are the same,
> non-deterministic corruption (?) of one input to r.series or
> t.rast.series.
> I have encountered this error on several disks, mirrored HDDs, single
> HDD, and now on an SSD. I don't think that this is a disk problem,
> rather, something that r.series or t.rast.series is "doing" to the
> files it operates on.
> Is there some possibility that one of these commands is leaving a file
> "open" or in some kind of intermediate state that prevents subsequent
> commands from accessing the file?
> I'll try to create a sample dataset to send over. In the meantime is
> there any kind of diagnostic information that I can report back with?
Are you using a mask, as was the case in the thread you cite ?
Moritz
