[GRASS-dev] [GRASS GIS] #2750: LZ4 when writing raster rows; better than double I/O bound r.mapcalc speed
trac at osgeo.org
Tue Oct 13 11:41:06 PDT 2015
Reporter: sprice | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.1.0
Component: Raster | Version: svn-trunk
Resolution: | Keywords: ZLIB LZ4 ZSTD
CPU: OSX/Intel | Platform: MacOSX
Comment (by sprice):
I considered writing a more general function for compression but I held
off for two reasons:
1) There seems to be a lot of very specific code depending on exactly what
you're doing. For example, for read_data_fp_compressed() there was
functionality hidden in G_zlib_read to save a header for each compressed
row. Or the use of G_ZLIB_COMPRESSED_NO ('0') as a flag for FP
compression, vs various integers defining CELL compression. To keep
backwards compatibility, I delt with the different formats (CELL vs NULL
vs FCELL/DCELL) on a case-by-case basis.
2) I'm not familiar with the best practices for the code in GRASS GIS. I'd
encourage someone else to create new files (or libraries) as required. I
can help as required, but I'm concerned that as each edge case is
considered (as mentioned above) there won't be all that much common code
between the various compression uses.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2750#comment:15>
