[GRASS-dev] v.voronoi producing wrong output
Maris Nartiss maris.gis at gmail.com
Wed Oct 14 10:15:25 PDT 2015
Hello,
I can not reproduce the issue on my ~AMD64 Gentoo system.
GRASS versija: 7.1.svn
GRASS SVN revision: 66489M
Build date: 2015-10-14
Build platform: x86_64-unknown-linux-gnu
Try to install GRASS 7.1 nightly and report back if you still have
problems with it.
I don't see any recent changes to v.voronoi and valgrind also does not
complain - will be hard to trace down if problem has not been solved
in 7.1 by accident.
Māris.
2015-10-14 15:51 GMT+03:00 Cev Hillan <cevhillan at hotmail.com>:
> Hello all,
> As it is my first mail on this list, I would like to thank the devs and
> the whole team for the great work done in GRASS.
> Before filing up a bug report I would like your advice on the following
> problem : the output of v.voronoi is wrong (additionnal lines and/or
> holes) for a set of around 4600 points in EPSG:27572 (in meters).
> These are the steps to reproduce the bug :
> v.in.ogr --overwrite input=C:\XXXX\points.shp output=points
> g.region -p vect=points n=n+100 s=s-100 e=e+100 w=w-100 res=0.01 -a
> v.voronoi --overwrite --verbose input=points output=voronoi_areas
> The dataset is linked to the email, it is in EPSG:27572.
> You will also find a picture of the (wrong) output.
> The output of voronoi command is :
> Reading features...
> WARNING: La couche vectorielle <voronoi_areas> existe déjà et va être écrasé
> Utilisation du format natif
> Voronoi triangulation for 4622 points...
> Writing edges...
> Writing features...
> Writing attributes...
> Searching for topology errors...
> WARNING: Le nombre de centroïdes dépasse le nombre de surfaces : 4622 > 3478
> WARNING: Nombre de contours incorrects: 5058
> WARNING: Nombre de centroïdes en dehors de surfaces: 308
> WARNING: Nombre de centroïdes dupliqués:   881
> Cleaning output topology
> Reading features...
> Accrochage des sommets passe 1 : sélection des points
> Accrochage des sommets passe 2 : assignation des ancrages de sommets
> Accrochage des sommets passe 3 : accrochage sur les points assignés
> Sommets accrochés : 663
> Nouveau sommet : 862
> Intersections : 54331
> Removed duplicates: 491
> Modifications: 0
> Removing dangles...
> Removed lignes : 3
> Removed dangles: 3
> Removing bridges...
> Removed lines: 0
> Removed bridges: 0
> Construction de la topologie pour la carte vectorielle
> <voronoi_areas at Test>...
> Enregistrement des primitives ...
> 72112 primitives registered
> 139602 vertices registered
> Construction des surfaces ...
> 31830 areas built
> One isle built
> Attachement des îles ...
> Attachement des centroïdes ...
> La topologie a bien été construite
> Nombre de nœuds: 35661
> Nombre de primitives: 72112
> Nombre de points: 0
> Nombre de lignes :0
> Nombre de contours: 67490
> Nombre de centroïdes: 4622
> Nombre de surfaces: 31830
> Nombre d'îles: 1
> WARNING: Nombre de centroïdes dupliqués:   114
> v.voronoi terminé.
> This is the output of g.version -breg :
> version=7.0.1
> date=2015
> revision=65800
> build_date=2015-07-31
> build_platform=i686-pc-mingw32
>     ./configure  '--with-libs=/c/OSGeo4W/lib /c/OSGeo4W/apps/msys/lib
> /c/osgeo4w/usr/src/grass701/mswindows/osgeo4w/lib'
> '--with-includes=/c/OSGeo4W/include /c/OSGeo4W/apps/msys/include'
> --libexecdir=/c/OSGeo4W/bin --prefix=/c/OSGeo4W/apps/grass
> --bindir=/c/OSGeo4W/bin --includedir=/c/OSGeo4W/include --disable-x
> --without-x --with-cxx --enable-shared --enable-largefile
> --with-opengl=windows --with-fftw --with-freetype
> --with-proj-share=/c/OSGeo4W/share/proj
> --with-gdal=/c/osgeo4w/usr/src/grass701/mswindows/osgeo4w/gdal-config
> --with-geos=/c/osgeo4w/usr/src/grass701/mswindows/osgeo4w/geos-config
> --with-liblas=/c/osgeo4w/usr/src/grass701/mswindows/osgeo4w/liblas-config --with-sqlite
> --with-curses --with-regex --with-nls
> --with-freetype-includes=/c/OSGeo4W/include/freetype2 --with-odbc
> --with-cairo --with-cairo-includes=/c/OSGeo4W/include/cairo --with-postgres
> libgis_revision=64733
> libgis_date="2015-02-25 01:56:29 +0100 (st, 25 2 2015) "
> proj4=4.8.0
> gdal=1.11.2
> geos=3.4.2
> sqlite=3.7.17
> I also tried on a Unix machine on which I built GRASS with the same results.
> I tried to get a small subset of points and got down to 8 points
> producing a wrong output. Point subset and output image is also linked
> to this email.
> I searched existing bugs and tried to increase resolution with g.region
> with no improvement;
> Do you have any ideas ? Should I file in a bug or am I using the tools
> in the wrong way ?
> Thanks for your thoughts,
> Cev.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
