[GRASS-dev] db_start_driver without window
Radim Blazek
radim.blazek at gmail.com
Thu Oct 15 00:55:15 PDT 2015
On Thu, Oct 15, 2015 at 9:00 AM, Markus Neteler <neteler at osgeo.org> wrote:
> On Wed, Oct 14, 2015 at 7:39 PM, Radim Blazek <radim.blazek at gmail.com> wrote:
>> When a driver is started from QGIS on Windows using db_start_driver ->
>> G_spawn_ex -> do_spawn -> win_spawn > CreateProcess, it opens black
>> window.
>> Is there a possibility to prevent opening that window by setting some
>> global Windows param before db_start_driver is called? If not, would
>> it be possible to prevent it by giving
>> CREATE_NO_WINDOW (or something like that) as dwCreationFlags to
>> CreateProcess in win_spawn?
> At time I see the 0 hardcoded in the function all in
> lib/gis/spawn.c
> static int win_spawn(const char *cmd, const char **argv, const char **envp,
> const char *cwd, HANDLE handles[3], int background,
> int shell)
> result = CreateProcess(
> program, /* lpApplicationName */
> args, /* lpCommandLine */
> NULL, /* lpProcessAttributes */
> NULL, /* lpThreadAttributes */
> 1, /* bInheritHandles */
> 0, /* dwCreationFlags */
> env, /* lpEnvironment */
> cwd, /* lpCurrentDirectory */
> &si, /* lpStartupInfo */
> &pi /* lpProcessInformation */
> @devs: related documentation:
> https://msdn.microsoft.com/en-us/library/windows/desktop/ms682425(v=vs.85).aspx
> --> therein page ref with the of "Process Creation Flags"
> --> CREATE_NO_WINDOW
> Did you try and this works then?
Not yet, I was not able to compile GRASS, it cannot find various
dependencies (zlib, regex, proj...) even if dev packages are
installed. I'll try again and post the problems.
Radim
