[GRASS-dev] [GRASS GIS] #2764: corrupt data written to FCELL and DCELL rasters, hard to re-produce
trac at osgeo.org
Fri Oct 16 11:53:51 PDT 2015
Reporter: dylan | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.1.0
Component: Raster | Version: unspecified
Keywords: | CPU: x86-64
Platform: Linux |
I think that I may have made some progress after a long battle with some
very hard to reproduce [http://osgeo-org.1560.x6.nabble.com/Error-reading-
raster-data-for-row-xxx-only-when-using-r-series-and-t-rast-series-
td5229569.html#a5230287 errors]. The attached bash scripts can be used in
any location (LL and projected give the same results on my machine) and
will test the following:
1. generate a new DCELL map via `r.surf.gauss`
2. test resulting map via `r.univar`
3. repeat process, overwriting previous DCELL map
I have noticed that running these tests serially and in parallel produce
the same results: ~2% of the maps generated generate an error message when
read via `r.univar`. This is the same error message [http://osgeo-
org.1560.x6.nabble.com/Error-reading-raster-data-for-row-xxx-only-when-
using-r-series-and-t-rast-series-td5229569.html that started my recent
string of postings to GRASS-dev]. After applying a patch (#2762) to add
some more information to the error message, I see:
ERROR: Error reading raster data for row 1949 of <testing_gauss_7>
(buffer size mismatch)
Tests were performed using r66514 of grass_trunk.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2764>
