[GRASS-dev] Test report: different message breaks the test
Pietro
peter.zamb at gmail.com
Fri Oct 16 13:33:40 PDT 2015
Il 16 ott 2015 5:38 PM, "Vaclav Petras" <wenzeslaus at gmail.com> ha scritto:
> Hi,
> it seems that some change in error message broke the test. I'm not sure
what should the the general approach in these cases. The test should be
changed with the message that's clear but the question is how precise we
want the message test to be. Perhaps we want to test there is some message
or that there is a string such as "SQL" or name of the column in it. Any
opinions?
Yes, I can remove the test on the error message, probably I was just too
pendant...
The important thing is that an exception is raised!
Pietro
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151016/4f644262/attachment.html>
