[GRASS-dev] [GRASS GIS] #2766: it is not possible to set other column when working with v.db.join from gui
trac at osgeo.org
Sat Oct 17 02:20:29 PDT 2015
Reporter: lfurtkevicova | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 7.1.0
Component: Database | Version: 7.0.1
Keywords: | CPU: x86-64
Platform: Linux |
Problem with joinig database table to a vector map table using v.db.join
from gui:
parameters `map`, `column` and `other_table` are OK, but it isn't possible
to set `other_column`
Ticket URL: <https://trac.osgeo.org/grass/ticket/2766>
