[GRASS-dev] odd behavior from t.register when loading from file and no "end date" is specified
Markus Neteler
neteler at osgeo.org
Sun Oct 18 08:01:38 PDT 2015
On Sun, Oct 18, 2015 at 3:24 PM, Sören Gebbert
<soerengebbert at googlemail.com> wrote:
> Hi all,
> sorry for my late response.
> The documentation is unfortunately not clear about the use of "-i"
> flag, increment and text files. I will update this.
> The main idea is:
> The -i flag and the increment option will only work if a start time
> was defined at the command line (no end time!).
> In case time stamps are set in the input file, then the -i flag and
> the increment option should not be used.
Wish:
It would be great to either drop -i and let t.register manage it by
itself upon presence of start time + no end time + increment defined
(warning/error otherwise).
Or at least, to generate some more messages in case of conflicting settings.
I had the same problem myself and it took me (too) long to identify the problem.
thanks
Markus
