[GRASS-dev] [GRASS GIS] #2428: r.external to accept gdal config options
trac at osgeo.org
Mon Oct 19 12:33:40 PDT 2015
Reporter: perrygeo | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.1.0
Component: Default | Version: svn-trunk
Resolution: | Keywords: r.external
CPU: x86-64 | Platform: Unspecified
Comment (by glynn):
Replying to [comment:4 dylan]:
> Could this same block of code be used within `r.external`? I don't fully
understand how `r.external` works, so I suppose that it is more
complicated than this.
r.external itself just sets up the "link" between GRASS and the data file.
The actual I/O occurs in lib/raster (gdal.c, open.c, get_row.c, close.c)
when a GRASS module reads the map.
But the data which r.external controls is per-map, while this appears to
be a global setting. What happens when a module reads multiple GDAL-linked
maps with different settings? It might make more sense to set this in
Rast_init_gdal() from an environment variable or $GISRC variable.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2428#comment:5>
