[GRASS-dev] [GRASS GIS] #2774: v.to.3d - create column in the resulting 2d vector layer when using reverse transformation
GRASS GIS trac at osgeo.org
Wed Oct 21 10:57:53 PDT 2015
transformation
 Reporter:  PedroNGV     |      Owner:  grass-dev@…
     Type:  enhancement  |     Status:  new
 Priority:  normal       |  Milestone:  7.0.2
Component:  Vector       |    Version:  unspecified
 Keywords:               |        CPU:  Unspecified
 Platform:  Unspecified  |
 When using v.to.3d reverse transformation (-r), to store the height of
 points in the resulting 2d layer ('column' parameter), we need to add a
 new column in the original 3d layer, to get the column name and to store
 in the 2d layer.
 The ideal should be simply give a name and create a new column in the new
 vector layer (2d). Something like the 'column' parameter of v.random (Name
 of column for z values; Writes z values to column), where we just give a
 name to the height column of the resulting layer.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2774>
