[GRASS-dev] Open/close db drivers order
Radim Blazek
radim.blazek at gmail.com
Fri Oct 23 00:18:46 PDT 2015
On Thu, Oct 22, 2015 at 11:58 PM, Glynn Clements
<glynn at gclements.plus.com> wrote:
>> But there may be other file descriptors not related to db drivers. Is
>> it possible to close all of them in driver process?
> Maybe.
> When fork() clones a process, the descriptor table is cloned along
> with everything else. When the process changes its program with
> execve(), any descriptors without the FD_CLOEXEC flag remain open.
> But the new program won't know of their existence, where they came
> from, what they refer to, etc. The "knowledge" about the descriptors
> only exists in the original program, so closing specific descriptors
> (or setting their close-on-exec flags) has to be done prior to the
> execve().
> Once the program is changed and that information is lost, about the
> only option available to the driver is to close *every* open
> descriptor except for 0, 1 and 2 (standard input/output/error). This
> needs to be done before calling any library function which might
> create additional descriptors (which in practice means almost any
> library function).
> Even that is complicated by the fact that there's no standard
> mechanism for discovering the highest open descriptor number. You just
> have to iterate until reaching some arbitrary maximum, or until some
> (again, arbitrary) number of consecutive descriptors are found to be
> unused (by close() failing with EBADF), and hope that's all of them.
Should it better go to the original program between fork() and execve()
or into the driver executable?
> The only robust solution is for the original program to systematically
> set the close-on-exec flag on every descriptor *except* those which
> are meant to be inherited.
The original program may be using third party libraries which will
never care of.
Radim
> The fact that descriptors are always inherited across fork() and
> preserved across execve() by default is generally considered to be a
> mistake in the POSIX API, but we're now stuck with it.
> Glynn Clements <glynn at gclements.plus.com>
