[GRASS-dev] v.rast.stats: ERROR: Input window changed while maps are open for read.
Helmut Kudrnovsky
hellik at web.de
Sat Oct 24 02:05:21 PDT 2015
hi,
by testing the manual example of v.rast.stats, I get following error:
v.rast.stats --verbose map=myzipcodes_wake at gbiftest
raster=elevation at PERMANENT column_prefix=elev
method=minimum,maximum,average,stddev,percentile
Adding columns '['elev_minimum DOUBLE PRECISION', 'elev_maximum DOUBLE
PRECISION', 'elev_average DOUBLE PRECISION', 'elev_stddev DOUBLE PRECISION',
'elev_percentile_90 DOUBLE PRECISION']'
Adding column <elev_minimum> to the table
Adding column <elev_maximum> to the table
Adding column <elev_average> to the table
Adding column <elev_stddev> to the table
Adding column <elev_percentile_90> to the table
Processing data (13 categories)...
ERROR: Input window changed while maps are open for read. Map name
<myzipcodes_wake_8088.0>
Updating the database ...
Statistics calculated from raster map <elevation at PERMANENT> and uploaded to
attribute table of vector map <myzipcodes_wake>.
DEBUG=3 output
<http://osgeo-org.1560.x6.nabble.com/file/n5232313/grass_cmd_output.txt>
tested with
System Info
GRASS version: 7.1.svn
GRASS SVN revision: 66569
Build date: 2015-10-22
Build platform: i686-pc-mingw32
GDAL: 1.11.3
PROJ.4: 4.8.0
GEOS: 3.5.0
SQLite: 3.7.17
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/v-rast-stats-ERROR-Input-window-changed-while-maps-are-open-for-read-tp5232313.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
