[GRASS-dev] [GRASS GIS] #2779: v.external compile error --without-gdal --with-postgres
trac at osgeo.org
Sat Oct 24 14:49:47 PDT 2015
Reporter: Papillon81 | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.2
Component: Vector | Version: 7.0.1
Keywords: | CPU: x86-64
Platform: Linux |
The module v.external gives a compile error when compiling GRASS 7.0.1
--without-gdal --with-postgres.
The following error shows up:
main.c:27:21: fatal error: ogr_api.h: No such file or directory
It seems like the ogr_api.h header should be conditionally included in the
main.c file or the v.external module should not be compiled at all when
gdal is disabled.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2779>
