[GRASS-dev] [GRASS GIS] #2358: Strange behaviour with v.net on GRASS GIS 7
trac at osgeo.org
Tue Oct 27 07:04:45 PDT 2015
Reporter: lluis | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 7.0.0
Component: Vector | Version: svn-releasebranch70
Resolution: wontfix | Keywords: Ubuntu 14.04, v.net, attributes
CPU: x86-64 | Platform: Linux
Changes (by mlennert):
* status: new => closed
* resolution: => wontfix
Comment:
Replying to [ticket:2358 lluis]:
> Hi,
> I'm working with GRASS GIS 7.0.0svn (r59969) on Ubuntu 14.04 LTS and I'm
experiencing a strange behaviour when using v.net. I have set of nodes
that I want to connect to a collection of streets on a network.
> When I execute "v.net streets points=libraries out=net op=connect
thresh=150" on GRASS GIS 6.4.4, the new arc(s)/line(s) that connect the
points to the network, inherit all the attributes (even the 'cat' value)
of the pre-existing arcs. But, when I execute the same command on GRASS
GIS 7.0.0 that expected behaviour doesn't take place. The new
arc(s)/line(s) generated with GRASS 7 doesn't have attributes, a new cat
value is generated for each new line but they doesn't appear on the
attribute table...
This is not a bug, but a feature, although maybe not documented enough.
The previous behaviour could be considered a bug, as there is no real
reason to believe that attributes of the line connected to are valid for
the line created for the connection. This was, therefore, corrected two
years ago in v.net. Now v.net attributes new, unique, cat values to the
new arcs, but these values do not have entries in the attribute table.
The easiest way to add extra lines into the attribute table for these new
arcs is to use
v.to.db map op=cat
It is then the responsibility of the user to fill in the other attribute
fields for these new arcs (using v.db.update).
However, grass7 also provides the new '-s' flag which, instead of creating
connection arcs, snaps the points to the closest line. In many
applications this is more realistic then the connection arcs, and it has
the added value that the points are then on potential paths and thus one
can calculate centrality indicators for these points.
I will file an enhancement ticket that proposes to make this behaviour the
default behaviour, as I believe that this will avoid many headaches for
many users. In the meantime, I'm closing this bug.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2358#comment:1>
