[GRASS-dev] [GRASS GIS] #2782: modeler problems with variable
GRASS GIS trac at osgeo.org
Tue Oct 27 08:54:31 PDT 2015
 Reporter:  lucadelu     |      Owner:  grass-dev@…
     Type:  defect       |     Status:  new
 Priority:  normal       |  Milestone:  7.0.2
Component:  wxGUI        |    Version:  unspecified
 Keywords:  modeler      |        CPU:  Unspecified
 Platform:  Unspecified  |
 Using the modeler I found two problems with names for new map when command
 are loop and it use ''%map'' variable:
 - using something like %map.new in the python tab the ''.new'' is not
 recognized and I get an error during validation
 - using something like %map.%new where new is defined as variable in the
 python code there are to many quotes after the name
 You can see the problem in the attached png and try it using the gxm file
 and north carolina landsat dataset.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2782>
