[GRASS-dev] [GRASS GIS] #2784: add a g.mkfontcap run for OSGeo4W wingrass
trac at osgeo.org
Tue Oct 27 09:10:20 PDT 2015
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 7.0.2
Component: Display | Version: svn-trunk
Keywords: | CPU: Unspecified
Platform: MSWindows 7 |
in C:\OSGeo4W\apps\grass\grass-7.0.2RC1\etc\fontcap
cyrilc|Cyrillic|0|c:\osgeo4w\usr\src\grass702RC1\dist.i686-pc-
mingw32\fonts\cyrilc.hmp|0|utf-8|
gothgbt|Gothic Great Britain
triplex|0|c:\osgeo4w\usr\src\grass702RC1\dist.i686-pc-
mingw32\fonts\gothgbt.hmp|0|utf-8|
gothgrt|Gothic German triplex|0|c:\osgeo4w\usr\src\grass702RC1\dist.i686
-pc-mingw32\fonts\gothgrt.hmp|0|utf-8|
gothitt|Gothic Italian triplex|0|c:\osgeo4w\usr\src\grass702RC1\dist.i686
-pc-mingw32\fonts\gothitt.hmp|0|utf-8|
greekc|Greek complex|0|c:\osgeo4w\usr\src\grass702RC1\dist.i686-pc-
mingw32\fonts\greekc.hmp|0|utf-8|
greekcs|Greek complex script|0|c:\osgeo4w\usr\src\grass702RC1\dist.i686
-pc-mingw32\fonts\greekcs.hmp|0|utf-8|
greekp|Greek plain|0|c:\osgeo4w\usr\src\grass702RC1\dist.i686-pc-
mingw32\fonts\greekp.hmp|0|utf-8|
greeks|Greek simplex|0|c:\osgeo4w\usr\src\grass702RC1\dist.i686-pc-
mingw32\fonts\greeks.hmp|0|utf-8|
italicc|Italian complex|0|c:\osgeo4w\usr\src\grass702RC1\dist.i686-pc-
mingw32\fonts\italicc.hmp|0|utf-8|
italiccs|Italian complex small|0|c:\osgeo4w\usr\src\grass702RC1\dist.i686
-pc-mingw32\fonts\italiccs.hmp|0|utf-8|
italict|Italian triplex|0|c:\osgeo4w\usr\src\grass702RC1\dist.i686-pc-
mingw32\fonts\italict.hmp|0|utf-8|
romanc|Roman complex|0|c:\osgeo4w\usr\src\grass702RC1\dist.i686-pc-
mingw32\fonts\romanc.hmp|0|utf-8|
romancs|Roman complex small|0|c:\osgeo4w\usr\src\grass702RC1\dist.i686-pc-
mingw32\fonts\romancs.hmp|0|utf-8|
romand|Roman duplex|0|c:\osgeo4w\usr\src\grass702RC1\dist.i686-pc-
mingw32\fonts\romand.hmp|0|utf-8|
romans|Roman simplex|0|c:\osgeo4w\usr\src\grass702RC1\dist.i686-pc-
mingw32\fonts\romans.hmp|0|utf-8|
romant|Roman triplex|0|c:\osgeo4w\usr\src\grass702RC1\dist.i686-pc-
mingw32\fonts\romant.hmp|0|utf-8|
scriptc|Script complex|0|c:\osgeo4w\usr\src\grass702RC1\dist.i686-pc-
mingw32\fonts\scriptc.hmp|0|utf-8|
scripts|Script simplex|0|c:\osgeo4w\usr\src\grass702RC1\dist.i686-pc-
mingw32\fonts\scripts.hmp|0|utf-8|
the font paths in OSGeo4W wingrass shows to the paths of the build
server/environment and not to the local ones.
there is
https://trac.osgeo.org/grass/browser/grass/trunk/mswindows/osgeo4w/postinstall.bat
adding similar we do for the standalone installer:
FileWrite $0 'rem #$\r$\n'
547 FileWrite $0 'rem # Run g.mkfontcap outside a grass
session during installation$\r$\n'
548 FileWrite $0 'rem #$\r$\n'
549 FileWrite $0 'rem
#########################################################################$\r$\n'
550 FileWrite $0 'echo Setup of
WinGRASS-${VERSION_NUMBER}$\r$\n'
551 FileWrite $0 'echo Generating the font configuration file
by scanning various directories for fonts.$\r$\n'
552 FileWrite $0 'echo Please wait. Console window will close
automatically ....$\r$\n'
553 FileWrite $0 '$\r$\n'
554 FileWrite $0 'rem set gisbase$\r$\n'
555 FileWrite $0 'set GISBASE=$INSTALL_DIR$\r$\n'
556 FileWrite $0 '$\r$\n'
557 FileWrite $0 'rem set path to freetype dll$\r$\n'
558 FileWrite $0 'set
FREETYPEBASE=$INSTALL_DIR\extrabin;$INSTALL_DIR\msys\bin;$INSTALL_DIR\lib$\r$\n'
559 FileWrite $0 '$\r$\n'
560 FileWrite $0 'rem set dependecies path$\r$\n'
561 FileWrite $0 'set PATH=%FREETYPEBASE%;%PATH%$\r$\n'
562 FileWrite $0 '$\r$\n'
563 FileWrite $0 'rem GISRC must be set$\r$\n'
564 FileWrite $0 'set GISRC=dummy$\r$\n'
565 FileWrite $0 '$\r$\n'
566 FileWrite $0 'rem run g.mkfontcap outside a grass
session$\r$\n'
567 FileWrite $0 '"%GISBASE%\bin\g.mkfontcap.exe" -o$\r$\n'
should solve this problem
Ticket URL: <https://trac.osgeo.org/grass/ticket/2784>
