[GRASS-dev] no grass plugin in qgis installed from osgeo4w
Veronica Andreo veroandreo at gmail.com
Tue Oct 27 09:35:30 PDT 2015
2015-10-27 13:22 GMT-03:00 Moritz Lennert <mlennert at club.worldonline.be>:
> AFAIK, GRASS access via Processing does not depend on the grass plugin.
>> However, you need to activate GRASS 7 in Processing->Options->Service
>> providers->Grass 7.
> Yes! Thanks much, Moritz! Was searching in the wrong place (hihihi). This
solved the issue with using grass tools through Processing.
Still grass plugin missing.
Thanks so much!
Vero
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151027/03029548/attachment.html>
