[GRASS-dev] [GRASS GIS] #2785: pygrass util set_path bug
trac at osgeo.org
Wed Oct 28 04:16:28 PDT 2015
Reporter: krejcmat | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.1
Component: PyGRASS | Version: svn-trunk
Resolution: | Keywords: path
CPU: x86-64 | Platform: Linux
Changes (by martinl):
* milestone: => 7.0.1
Old description:
> Hi,
> The current code doesn't count with parameters of the function
> "from grass.pygrass.utils import set_path". Diff[1] is below.
> thanks
> Matej
> [1]
> Index: lib/python/pygrass/utils.py
> --- lib/python/pygrass/utils.py (revision 66629)
> +++ lib/python/pygrass/utils.py (working copy)
> @@ -313,7 +313,7 @@
> pathlib = os.path.join(path, dirname)
> if os.path.exists(pathlib):
> # we are running the script from the script directory
> - sys.path.append(os.path.abspath(path))
> + sys.path.append(os.path.abspath(pathlib))
> else:
> # running from GRASS GIS session
> path = get_lib_path(modulename, dirname)
New description:
thanks
Matej
[1]
@@ -313,7 +313,7 @@
else:
Ticket URL: <https://trac.osgeo.org/grass/ticket/2785#comment:1>
