[GRASS-dev] compiling GRASS fails at configure, unable to locate GDAL library
Markus Neteler
neteler at osgeo.org
Thu Oct 29 02:52:33 PDT 2015
On Thu, Oct 29, 2015 at 10:49 AM, Paulo van Breugel
<p.vanbreugel at gmail.com> wrote:
> Hi, I am trying to make a fresh install of GRASS master, something I do
> routinely about every week (on Ubuntu 14.04).
> --with-pthread
(not sure if you want that, see other discussions here)
>> checking for gdal-config... /usr/local/bin/gdal-config
>> configure: error: *** Unable to locate GDAL library.
As usual, check config.log for the problem.
Markus
