[GRASS-dev] [GRASS GIS] #2788: implement r.export and v.export
GRASS GIS trac at osgeo.org
Thu Oct 29 09:07:53 PDT 2015
 Reporter:  martinl             |      Owner:  grass-dev@…
     Type:  enhancement         |     Status:  new
 Priority:  major               |  Milestone:  7.1.0
Component:  Default             |    Version:  svn-trunk
 Keywords:  r.export, v.export  |        CPU:  Unspecified
 Platform:  Unspecified         |
 It would be nice to implement `r.export` and `v.export` similarly to
 G7:r.import and G7:v.export. These modules would call `r.out.gdal`/
 `v.out.ogr` and then reproject output files to defined crs. I can see
 several scenarious:
  1. add to `r.out.gdal` and `v.out.ogr` new parameter `output_crs`,
 reprojection will be done by GDAL
  1. create new temporary location in output crs, reproject data
 (`r|v.proj`) and then export
  1. export data to temporary output file and then to reproject by GDAL
 It seems that 2) fits in the best way to the current `r.import` and
 `v.import` approach. Any options?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2788>
