[GRASS-dev] [GRASS GIS] #2775: Hangs when closing db drivers
GRASS GIS trac at osgeo.org
Fri Oct 30 06:36:26 PDT 2015
  Reporter:  rblazek      |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.0.1
 Component:  Database     |    Version:  unspecified
Resolution:               |   Keywords:
       CPU:  Unspecified  |   Platform:  Linux
Comment (by rblazek):
 More from Glynn about the possibility to close all descriptors
 https://lists.osgeo.org/pipermail/grass-dev/2015-October/077010.html
 which does not seem to be optimal.
 I think that both patches should be applied. The second is resolving the
 real problem.
 The first, explicitly sending close procedure to driver cannot harm and it
 should also cover all cases when a descriptor is opened (even not db
 related) without setting FD_CLOEXEC.
 Backport would be useful.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2775#comment:3>
