[GRASS-dev] [GRASS GIS] #2784: add a g.mkfontcap run for OSGeo4W wingrass
trac at osgeo.org
Sat Oct 31 03:17:41 PDT 2015
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 7.0.2
Component: Display | Version: svn-trunk
Resolution: | Keywords:
CPU: Unspecified | Platform: MSWindows 7
Comment (by hellik):
Replying to [ticket:2784 hellik]:
> the font paths in OSGeo4W wingrass shows to the paths of the build
server/environment and not to the local ones.
> there is
https://trac.osgeo.org/grass/browser/grass/trunk/mswindows/osgeo4w/postinstall.bat
> adding similar we do for the standalone installer:
> FileWrite $0 'rem #$\r$\n'
> 547 FileWrite $0 'rem # Run g.mkfontcap outside a grass
session during installation$\r$\n'
> 548 FileWrite $0 'rem #$\r$\n'
> 549 FileWrite $0 'rem
#########################################################################$\r$\n'
> 550 FileWrite $0 'echo Setup of
WinGRASS-${VERSION_NUMBER}$\r$\n'
> 551 FileWrite $0 'echo Generating the font configuration file
by scanning various directories for fonts.$\r$\n'
> 552 FileWrite $0 'echo Please wait. Console window will close
automatically ....$\r$\n'
> 553 FileWrite $0 '$\r$\n'
> 554 FileWrite $0 'rem set gisbase$\r$\n'
> 555 FileWrite $0 'set GISBASE=$INSTALL_DIR$\r$\n'
> 556 FileWrite $0 '$\r$\n'
> 557 FileWrite $0 'rem set path to freetype dll$\r$\n'
> 558 FileWrite $0 'set
FREETYPEBASE=$INSTALL_DIR\extrabin;$INSTALL_DIR\msys\bin;$INSTALL_DIR\lib$\r$\n'
> 559 FileWrite $0 '$\r$\n'
> 560 FileWrite $0 'rem set dependecies path$\r$\n'
> 561 FileWrite $0 'set PATH=%FREETYPEBASE%;%PATH%$\r$\n'
> 562 FileWrite $0 '$\r$\n'
> 563 FileWrite $0 'rem GISRC must be set$\r$\n'
> 564 FileWrite $0 'set GISRC=dummy$\r$\n'
> 565 FileWrite $0 '$\r$\n'
> 566 FileWrite $0 'rem run g.mkfontcap outside a grass
session$\r$\n'
> 567 FileWrite $0 '"%GISBASE%\bin\g.mkfontcap.exe" -o$\r$\n'
> should solve this problem
patch for trunk accordingly above attached. reviewing welcome.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2784#comment:1>
