[GRASS-dev] [GRASS GIS] #2790: Output of t.rast.list with method=comma and columns=name does not differ from output with columns=id
GRASS GIS trac at osgeo.org
Sat Oct 31 08:05:39 PDT 2015
 Reporter:  veroandreo   |      Owner:  grass-dev@…
     Type:  defect       |     Status:  new
 Priority:  normal       |  Milestone:
Component:  Temporal     |    Version:  svn-trunk
 Keywords:  t.rast.list  |        CPU:  x86-64
 Platform:  Linux        |
 When using t.rast.list column=name method=comma,
 both map name and mapset name are printed, so it does not differ from
 asking column=id.
 GRASS 7.1.svn (latlong_wgs84):~ > t.rast.list input=precip_abs
 order=start_time columns=name method=comma
 prec_1 at pruebas,prec_2 at pruebas,prec_3 at pruebas,prec_4 at pruebas,prec_5 at pruebas,prec_6 at pruebas,prec_7 at pruebas,prec_8 at pruebas,prec_9 at pruebas,prec_10 at pruebas,prec_11 at pruebas,prec_12 at pruebas
 order=start_time columns=id method=comma
 While several modules (r.colors, r.stats or r.series) can take this as
 input, r.hants (from add-ons) gives an error
 GRASS 7.1.svn (latlong_wgs84):~ > r.hants input=`t.rast.list
 input=precip_abs order=start_time columns=name method=comma` nf=2
 base_period=6 fet=10 suffix=_hants
 ERROR: Raster map <prec_1 at pruebas_hants> is not in the current mapset
        (pruebas)
 For r.hants it's of main importance that maps are temporally ordered and
 that's why I would prefer to use t.rast.list that orders maps as needed
 (instead of g.list, that depending on map names, could give a wrong
 order), but as the output includes "@mapset_name", maps are no longer
 recognized.
 Thanks a lot in advance :)
Ticket URL: <https://trac.osgeo.org/grass/ticket/2790>
