[GRASS-dev] Travis-ci and tests of grass 7
Rainer M Krug
Rainer at krugs.de
Thu Sep 3 08:24:13 PDT 2015
Hi
is anything happening in regards to the travis-ci integration? I did not
get any feedback or how I can submit it to the svn.
In regards to testing: I know about the python gunit tests [1]. Are
there any other tests which should be included in the scripts? Should
detailed results generated by the tests be uploaded somewhere in case of
an error? Or always? If yes, where?
Also, should the same tests be done for other versions?
Cheers,
Rainer
Rainer M Krug <Rainer at krugs.de> writes:
> Quick update: the tests are running, the forked github repo is
> https://github.com/rkrug/grass-ci
> and the travis-ci is here (the actually running one)
> https://travis-ci.org/rkrug/grass-ci/builds/77509876
> It looks good now.
> Cheers,
> Rainer
>> Hi Ivan, Hi Markus,
>> I have looked at the .travis.yml at
>> [https://trac.osgeo.org/grass/browser/grass/trunk/.travis.ym]l
>> and merged it with mine by
>> 1) moving the sections of the .travis.yml fiole into scripts:
>> - before_install :: .travis.$TRAVIS_OS_NAME.before_install.sh
>> - install :: .travis.$TRAVIS_OS_NAME.install.sh
>> - script :: .travis.$TRAVIS_OS_NAME.script.sh
>> 2) using a travis multiple OS [http://docs.travis-ci.com/user/multi-os/]
>> which sets the variable $TRAVIS_OS_NAME to "osx" or "linux" (hopefully
>> "windows" in the future as well)
>> So when testing on linux, the scripts with *.linux.*.sh are called, when
>> testing osx the one=s with *.osx.*.sh get called
>> 3) adding the different compiler to the matrix
>> So I end up with three separate test scenarios:
>> | - os: linux
>> | language: c
>> | compiler: gcc
>> | - os: linux
>> | language: c
>> | compiler: clang
>> | - os: osx
>> | compiler: objective-c
>> I forked [https://github.com/GRASS-GIS/grass-ci] and am running the test
>> at the moment - see [https://travis-ci.org/rkrug/grass-ci/builds/77484863]
>> for the tests.
>> They completed successful.
>> There is still some fine tuning which could be done, especially with
>> including of tests - which should not be to difficult.
>> What would be the easiest to get the new files into the grass repo, id=f
>> you are happy with it?
>> Cheers,
>> Rainer
>> Markus Neteler <neteler at osgeo.org> writes:
>>> Hi Ivan,
>>> I asked Rainer who is willing to contribute the MacOSX part (end of the month).
>>> See below.
>>> Thanks, Rainer!
>>> Markus
>>> On Fri, Aug 14, 2015 at 10:09 AM, Rainer M Krug <r.m.krug at gmail.com> wrote:
>>>> Envoyé de mon iPhone
>>>>> Le 14 août 2015 à 09:45, Markus Neteler <neteler at osgeo.org> a écrit :
>>>>> Hi Rainer,
>>>> Hi Markus,
>>>>> given your experience with homebrew, I wondered if you would be
>>>>> willing to assist in setting up a Travis-CI instance for OSX here:
>>>> Yes - That is my idea. To have a Travis-CI instance for all major OS should be the aim.
>>>>>> On Tue, Jul 21, 2015 at 11:52 AM, Ivan Minčík <ivan.mincik at gmail.com> wrote:
>>>>>> Hi all,
>>>>>> we have just integrated Travis Continuous Integration system [1] to the
>>>>>> GRASS source code. Every commit is now build in Travis [2] using gcc and
>>>>>> clang. In case the build fails, error message should go to GRASS-dev list.
>>>>>> 1 - https://trac.osgeo.org/grass/browser/grass/trunk/.travis.yml
>>>>>> 2 - https://travis-ci.org/GRASS-GIS/grass-ci
>>>>>> Ivan Minčík
>>>>>> ivan.mincik at gmail.com GPG: 0x79529A1E
>>>>>> http://imincik.github.io/0x79529A1E.key
>>>>>> ivan.mincik at gista.sk GPG: 0xD714B02C
>>>>>> http://imincik.github.io/0xD714B02C.key
>>>>> This works well for Linux now.
>>>>> Reading this email on qgis-psc, I got the impression that it is
>>>>> "simple" also for OSX:
>>>>>> On Fri, Aug 14, 2015 at 7:31 AM, Nyall Dawson <nyall.dawson at gmail.com> wrote:
>>>>>>> On 13 August 2015 at 04:32, Tim Sutton <tim at qgis.org> wrote:
>>>>>>> Awesome stuff Nyall - can you give any notes on what specifically you
>>>>>>> had to do to enable OS X testing?
>>>>>> Not much really... all the ground work was already in place and were
>>>>>> just waiting on Travis to open up multi OS builds again. Whoever setup
>>>>>> the homebrew install package (Larry?) made it super easy to install
>>>>>> the dependencies, and we already had 99% of the tests passing without
>>>>>> error on OSX. Michael Kirk had also already given this a shot so I was
>>>>>> able to borrow parts of his attempts which also helped a lot.
>>>>>> Nyall
>>>>>> _______________________________________________
>>>>>> Qgis-psc mailing list
>>>>>> Qgis-psc at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-psc
>>>>> Ivan does not have time for it but he's maybe willing to tell you how
>>>>> to log into the system.
>>>>> What do you think?
>>>> As you probably know, I have a running Travis-ci for OS X and it could be integrated there.
>>>> The homebrew recipe needs some alignment in this case (and possibly
>>>> a new more "official" home) but that should be relatively straight
>>>> forward.
>>>> At the moment I am on holiday but should be able to look at it in the last week of August.
>>>> Please remind me of you don't hear from me by end of August.
>>>> Cheers and thanks for the offer,
>>>> Rainer
>>>>> Markus
Footnotes:
[1] https://grass.osgeo.org/grass71/manuals/libpython/gunittest_running_tests.html
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax : +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer at krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150903/c1942317/attachment.pgp>
