[GRASS-dev] r.in.lidar: height above ground
Vaclav Petras
wenzeslaus at gmail.com
Thu Sep 3 19:49:49 PDT 2015
in r66094, I've added base raster map to r.in.lidar. When provided,
r.in.lidar with subtract its values from the points' z values. In this way,
one can get height about ground.
Needs testing before general anouncement, so feel free to do so.
Adding a simple suggestion how to do a benchmark or test.
Vaclav
https://trac.osgeo.org/grass/changeset/66094
PS: Just now I realized that this should have been the commit with word
news or feature or something for automatic extraction.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150903/f57f7fbb/attachment.html>
> g.region -p
north: 224028.45
south: 223266.45
west: 638557.28
east: 639319.28
nsres: 0.1
ewres: 0.1
rows: 7620
cols: 7620
cells: 58064400
> time r.in.lidar in=points.las out=test_pure
Projection of input dataset and current location appear to match
Reading data ...
100%
Writing to map ...
100%
r.in.lidar complete. 948239 points found in region.
real 0m8.088s
user 0m6.888s
sys 0m0.780s
> time r.in.lidar in=points.las out=test_hag_elevation base=elevation
Reading data ...
100%
Writing to map ...
100%
real 0m9.759s
user 0m9.084s
sys 0m0.624s
> time r.mapcalc "test_difference = (elevation + test_hag_elevation) - test_pure"
100%
real 0m15.292s
user 0m23.280s
sys 0m1.172s
> time r.univar test_difference
100%
total null and non-null cells: 58064400
total null cells: 57140606
Of the non-null cells:
n: 923794
minimum: -1.52588e-05
maximum: 1.52588e-05
range: 3.05176e-05
mean: -3.14659e-09
mean of absolute values: 1.36327e-07
standard deviation: 1.02145e-06
variance: 1.04336e-12
variation coefficient: -32462.2 %
sum: -0.00290679931640625
real 0m3.468s
user 0m3.428s
sys 0m0.000s
> time time v.in.lidar in=points.las out=test_plain_import_simple -tb
Scanning 948256 points...
100%
948256 points imported
real 0m3.384s
user 0m1.416s
sys 0m1.956s
> time time v.in.lidar in=points.las out=test_plain_import_no_topo -b
100%
real 1m46.292s
user 1m17.748s
sys 0m36.692s
100%
Building topology for vector map <test_plain_import at manual>...
Registering primitives...
948256 primitives registered
948256 vertices registered
Building areas...
100%
0 areas built
0 isles built
Attaching islands...
Attaching centroids...
100%
Number of nodes: 0
Number of primitives: 948256
Number of points: 948256
real 2m6.593s
user 1m39.080s
sys 0m36.060s
