[GRASS-dev] [GRASS-SVN] r66058 - grass/trunk/raster/r.support
Sören Gebbert soerengebbert at googlemail.com
Sat Sep 5 04:15:31 PDT 2015
2015-09-05 10:57 GMT+02:00 Markus Neteler <neteler at osgeo.org>:
> Hi,
> just a question on this change:
> On Sat, Aug 29, 2015 at 6:25 PM,  <svn_grass at osgeo.org> wrote:
>> Author: huhabla
>> Date: 2015-08-29 09:25:06 -0700 (Sat, 29 Aug 2015)
>> New Revision: 66058
>> Modified:
>>    grass/trunk/raster/r.support/main.c
>> Log:
>> raster module r.support: Use the history to store the map title
>> Modified: grass/trunk/raster/r.support/main.c
>> --- grass/trunk/raster/r.support/main.c 2015-08-29 07:37:11 UTC (rev 66057)
>> +++ grass/trunk/raster/r.support/main.c 2015-08-29 16:25:06 UTC (rev 66058)
>> @@ -154,8 +154,10 @@
>>         strncpy(title, title_opt->answer, MAX_TITLE_LEN);
>>         title[MAX_TITLE_LEN - 1] = '\0';        /* strncpy doesn't null terminate oversized input */
>>         G_strip(title);
>> -       G_debug(3, "map title= [%s]  (%d chars)", title, strlen(title));
>> -       Rast_put_cell_title(raster->answer, title);
>> +       G_debug(3, "map title= [%s]  (%li chars)", title, strlen(title));
>> +       Rast_read_history(raster->answer, "", &hist);
>> +       Rast_set_history(&hist, HIST_TITLE, title);
>> +       Rast_write_history(raster->answer, &hist);
> Is it the better practice?
IMHO yes in case of r.support, since it sets the title in the history.
The function Rast_put_cell_title()
sets the category title. However, it is indeed confusing that there
are titles in the history and category files.
The module r.info shows the title from the history and so should
r.support set the title in the history ... at least to my
understanding.
> If yes, should also the other modules  be updated?
I don't think so, since they set the title for the categories.
> grep Rast_put_cell_title */*.c
> r.clump/main.c:    Rast_put_cell_title(OUTPUT, title);
> r.drain/main.c:    Rast_put_cell_title(new_map_name, "Surface flow trace");
> r.external/link.c:    Rast_put_cell_title(output, title);
> r.his/main.c:    Rast_put_cell_title(name_r, "Red extracted from HIS");
> r.his/main.c:    Rast_put_cell_title(name_g, "Green extracted from HIS");
> r.his/main.c:    Rast_put_cell_title(name_b, "Blue extracted from HIS");
> r.horizon/main.c:        Rast_put_cell_title(shad_filename, msg_buff);
> r.in.ascii/main.c:    Rast_put_cell_title(output, title);
> r.in.bin/main.c:        Rast_put_cell_title(output, title);
> r.in.gdal/main.c:        Rast_put_cell_title(output, title);
> r.in.gdal/main.c:        Rast_put_cell_title(szBandName, title);
> r.in.gridatb/file_io.c:    Rast_put_cell_title(oname, buf);
> r.in.lidar/main.c:    Rast_put_cell_title(outmap, title);
> r.in.mat/main.c:    Rast_put_cell_title(map_name, map_title);
> r.in.png/main.c:        Rast_put_cell_title(ch->name, title);
> r.in.xyz/main.c:    Rast_put_cell_title(outmap, title);
> r.mfilter/main.c:    Rast_put_cell_title(out_name, title);
> r.param.scale/close_down.c:    Rast_put_cell_title(rast_out_name, map_title);
> r.recode/main.c:    Rast_put_cell_title(result, title);
> r.relief/main.c:    Rast_put_cell_title(sr_name, buf);
> r.resamp.bspline/main.c:    Rast_put_cell_title(out_opt->answer, title);
> r.resamp.filter/main.c:    Rast_put_cell_title(parm.rastout->answer, title);
> r.resamp.interp/main.c:    Rast_put_cell_title(rastout->answer, title);
> r.resamp.stats/main.c:    Rast_put_cell_title(parm.rastout->answer, title);
> r.thin/main.c:    Rast_put_cell_title(output, "Thinned linear features");
> r.tile/main.c:    Rast_put_cell_title(name, title);
Ciao
Sören
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
