[GRASS-dev] possible error in WIKI could cause data corruption
Michael Barton
Michael.Barton at asu.edu
Sat Sep 5 14:08:56 PDT 2015
> On Sep 5, 2015, at 11:26 AM, Markus Neteler <neteler at osgeo.org> wrote:
> On Sat, Sep 5, 2015 at 7:51 PM, Michael Barton <Michael.Barton at asu.edu> wrote:
>> I don’t know if this is bad advice in the GRASS WIKI or a bug in a GRASS
>> database module. I have some vector files that were somehow imported into a
>> dbf DBMS last year. I wanted to switch them all to sqlite. The GRASS WIKI
>> advises…
>> Convert automatically all GRASS 6 vector maps to GRASS 7 (including
>> attribute transfer from DBF to SQLite)
> https://grasswiki.osgeo.org/wiki/Convert_all_GRASS_6_vector_maps_to_GRASS_7
>> The vectors already had GRASS 7 topology, but I ran v.rebuild.all just to be
>> sure. No problem.
>> db.connect -d ran with no problem
>> But v.db.reconnect.all -cd did not create tables in the sqlite database
> But the sqlite file is there?
yes
>> and corrupted the existing connection of the first table it hit. Fortunately, I
>> made a backup of the mapset before I started this.
> Perhaps a problem on Mac?
> This is strange - I have converted so many mapsets like that ..., even
> with lots of vector maps inside.
> The wiki page is there for a long time, I didn't see such reports so far.
I had to make a new mapset and then copy the files from the old mapset to the new one. All went into sqlite fine that way.
>> GRASS 7.1.svn (Spain_fieldwork_medlands_ERTS89_Z30):~ > v.db.reconnect.all
>> -cd
>> Reconnecting vector map <catastro at surveyboundaries> (1 of 9)...
>> Copying table <catastro> to target database...
>> Traceback (most recent call last):
>> File
>> "/Applications/GRASS/GRASS-7.1.app/Contents/MacOS/scripts/db.droptable",
>> line 99, in <module>
>> main()
>> File
>> line 77, in main
>> used = grass.db.db_table_in_vector(table)
>> File
>> "/Applications/GRASS/GRASS-7.1.app/Contents/MacOS/etc/python/grass/script/db.py",
>> line 184, in db_table_in_vector
>> from vector import vector_db
>> ImportError: No module named vector
> Maybe something got broken in GRASS 7.1?
> I would definitely use 7.0 for such operations.
I’ll check
Michael
> Markus
>> ERROR: Unable to drop table <catastro>
>> Michael
>> ____________________
>> C. Michael Barton
>> Director, Center for Social Dynamics & Complexity
>> Professor of Anthropology, School of Human Evolution & Social Change
>> Head, Graduate Faculty in Complex Adaptive Systems Science
>> Arizona State University
>> voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
>> fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
>> www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
