[GRASS-dev] [GRASS GIS] #2737: importing vector and raster problem
GRASS GIS trac at osgeo.org
Thu Sep 10 08:07:02 PDT 2015
 Reporter:  carminem  |      Owner:  grass-dev@…
     Type:  defect    |     Status:  new
 Priority:  critical  |  Milestone:
Component:  Default   |    Version:  7.0.1
 Keywords:            |        CPU:  x86-64
 Platform:  Linux     |
 When I launch v.in.ogr and r.in.gdal I receive this error:
 D1/5: grass.script.core.start_command(): g.gisenv -n
 D1/5: G_set_program_name(): g.gisenv
 D2/5: G_option_to_separator(): key = separator -> sep = '
   File "/usr/lib/grass70/gui/wxpython/lmgr/frame.py", line 310, in
 <lambda>
     lambda event: self.RunSpecialCmd(event.cmd))
   File "/usr/lib/grass70/gui/wxpython/lmgr/frame.py", line 617, in
 RunSpecialCmd
     self.OnImportGdalLayers(event = None, cmd = command)
   File "/usr/lib/grass70/gui/wxpython/lmgr/frame.py", line 1679, in
 OnImportGdalLayers
     dlg = GdalImportDialog(parent = self, giface = self._giface)
   File "/usr/lib/grass70/gui/wxpython/gui_core/dialogs.py", line 1878, in
 __init__
     " ({mightNotWork})".format(mightNotWork=mightNotWork)))
 UnicodeEncodeError: 'ascii' codec can't encode character u'\xf9' in
 position 37: ordinal not in range(128)
 I use grass 7.0.1 in ubuntu 14.04.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2737>
