[GRASS-dev] [GRASS GIS] #2448: Fontconfig error with cairo on Windows
trac at osgeo.org
Thu Sep 10 08:43:12 PDT 2015
Reporter: annakrat | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.2
Component: Display | Version: 7.0.0
Resolution: | Keywords: font, text, legend, scale bar
CPU: Unspecified | Platform: MSWindows 8
Comment (by hellik):
Replying to [comment:43 wenzeslaus]:
> Replying to [comment:42 annakrat]:
> > Replying to [comment:41 hellik]:
> > > I've done some research, file permissions changed a lot between
Windows versions (7,8,10).
> > Unfortunately, no change. I wonder if the problem is something
different then permissions. The problem is I don't get any error during
installation. Maybe we could print more messages during the font
configuration? Thanks for all the work on this.
> What about that hardcoding of some fonts for MS Windows into a MS
Windows specific file? This is a great workaround and I have no idea how
it should be done but it seems that it is appropriate on a platform where
API is changing often and is under-documented.
see https://grass.osgeo.org/grass70/manuals/g.mkfontcap.html
there is a -s flag:
-s Write font configuration file to standard output instead of
$GISBASE/etc
a feasable way may be:
- another flag e.g. to write fontcap file to %APPDATA%GRASS7 where already
the addons are stored
- all the modules which are working with fonts seems to search for the
fontcap file in $GISBASE/etc; adding a second search path (e.g.
%APPDATA%GRASS7) to these modules if the file is not available in
$GISBASE/etc
Ticket URL: <https://trac.osgeo.org/grass/ticket/2448#comment:45>
