[GRASS-dev] [GRASS GIS] #2448: Fontconfig error with cairo on Windows
GRASS GIS trac at osgeo.org
Thu Sep 10 11:17:25 PDT 2015
  Reporter:  annakrat     |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.0.2
 Component:  Display      |    Version:  7.0.0
Resolution:               |   Keywords:  font, text, legend, scale bar
       CPU:  Unspecified  |   Platform:  MSWindows 8
Comment (by hellik):
 Replying to [comment:47 annakrat]:
 > Replying to [comment:44 hellik]:
 > > Replying to [comment:42 annakrat]:
 > > > Unfortunately, no change. I wonder if the problem is something
 different then permissions.
 > > I'm quite sure that it is a file writing permission issue in a usually
 non-writeable folder (c:\Program Files\your program\folder to change
 something) in win 8 and above.
 > > tested it on several win 7 boxes here, it works fine. unfortunately no
 win 8 oder win 10 box here on my side.
 > If you want to spend even more time on it, you can download/use windows
 10 for free, and run it in virtual box. But it is not just windows 10
 issue from what I've seen.
 see r66166
 GRASS-Installer.nsi.tmpl: attempt to fix #2448
 make folder and file writeable before run g.mkfontcap
 change after g.mkfontcap run back to only readable
 it's only in trunk, can you the test one of the next dailys?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2448#comment:50>
