[GRASS-dev] installing v.mapcalc fails
Paulo van Breugel
p.vanbreugel at gmail.com
Fri Sep 11 03:55:48 PDT 2015
On 11-09-15 12:31, Moritz Lennert wrote:
> On 11/09/15 10:56, Paulo van Breugel wrote:
>> I am trying to install v.mapcalc through g.extension, but I am getting
>> the following error message:
>> Fetching <v.mapcalc> from GRASS GIS Addons repository (be patient)...
>> Compiling...
>> yylex.c:9:27: fatal error: v.mapcalc.tab.h: No such file or
>> directory
>> #include "v.mapcalc.tab.h"
>> compilation terminated.
>> make: *** [OBJ.x86_64-unknown-linux-gnu/yylex.o] Error 1
>> ERROR: Compilation failed, sorry. Please check above error messages.
>> Any idea?
> Well, the file does not exist. I don't know if it ever did (I can't
> find it in the older versions in trac). Could you just try without
> that include line ?
I only see it mentioned in the make file in the line
.INTERMEDIATE: v.mapcalc.tab.c v.mapcalc.tab.h v.mapcalc.output
I remove it from there?
> Moritz
