[GRASS-dev] installing v.mapcalc fails
Vaclav Petras
wenzeslaus at gmail.com
Fri Sep 11 06:46:41 PDT 2015
On Fri, Sep 11, 2015 at 4:56 AM, Paulo van Breugel <p.vanbreugel at gmail.com>
wrote:
> I am trying to install v.mapcalc through g.extension, but I am getting the
> following error message:
> Fetching <v.mapcalc> from GRASS GIS Addons repository (be patient)...
Have you tried t.vect.algebra module in trunk (7.1)? I'm not sure if it
works on single vectors but it supports the following operations on a
single vector: AND, OR, DISJOINT OR, XOR, NOT, buffer_p, buffer_l, buffer_a.
https://grass.osgeo.org/grass71/manuals/t.vect.algebra.html#spatial-vector-operators
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150911/6504d731/attachment.html>
